BriefCam Administrator Guide
Fast Track Settings
Version2025 R1
LanguageEnglish
The values that appear by default in the Fast Track feature can be changed using the following settings:
Negative values are not supported in these settings, and it is recommended not to use values greater than 10,000 for FastTrackDefaultDistance and FastTrackMaxDistance, and 60 for FastTrackDefaultTimeRange.
