BriefCam Administrator Guide
Assigning a Tag to a Camera
Version2025 R1
LanguageEnglish
Once you have assigned tags in the Tag Management screen, you can then assign the tags to cameras as described below.
  1. In the Camera Management screen, click the tag Assign_Tags_icon.png icon from one of the cameras.
  2. In the Camera Tagging screen, select the tag or tags you want to assign to the camera.
  3. Click the Save button.
