Milestone AI Bridge support matrix
Milestone AI Bridge 1.5 and newer utilizes OAuth integration and is only supported by Milestone XProtect 2022R1 or newer.
Milestone AI Bridge 1.5 and newer - Supported XProtect versions
  • XProtect 2022R3 and newer: Install the Milestone XProtect Processing Server Admin Plugin for the XProtect Management Client.
  • XProtect 2022R2: Update your XProtect installation with the Milestone AI Bridge patch for XProtect 2022R2 and then install the Milestone XProtect Processing Server Admin Plugin for the XProtect Management Client.
  • XProtect 2022R1: Update your XProtect installation with the Milestone AI Bridge patch for XProtect 2022R1 and then install the Milestone XProtect Processing Server Admin Plugin for the XProtect Management Client.
  • XProtect 2021R2 and older: Unsupported.
