Verifying Milestone AI Bridge is running (Kubernetes)
After deploying the Milestone AI Bridge, you can verify all pods are running as expected by opening a terminal and running the following command
kubectl get pods -n aibridge
If you have created your own namespace, replace the aibridge namespace with your namespace after the -n parameter.
The output of the command will resemble the example below.
Your installation may contain additional pods running in your cluster, but the ones displayed below should be listed.
POD READY STATUS RESTARTS AGE
aib-aibridge-broker-ccc86479-676mc 1/1 Running 0 13m
aib-aibridge-connector-8c5b9dbf7-jdjcd 1/1 Running 0 13m
aib-aibridge-fuseki-dbb789678-s5nv5 1/1 Running 0 13m
aib-aibridge-health-58bf7fbcb7-4c8xj 1/1 Running 0 13m
aib-aibridge-kafka-broker-77cd764b4f-fh4ms 1/1 Running 0 13m
aib-aibridge-proxy-7bd9d9d59-9hpdj 1/1 Running 0 13m
aib-aibridge-streaming-8d75885d9-qqf9c 1/1 Running 0 13m
aib-aibridge-webservice-564d7dbc68-cwfrv 1/1 Running 0 13m
If you see aibridge-init-xxxxx pod in the list with the status of Running, the Milestone AI Bridge is still initializing and not ready for operations.
If the aibridge-init-xxxxx pod does not complete within a couple of minutes, you can check the log file of the pod by opening a terminal and running the following command:
kubectl logs aib-aibridge-init-<xxxxx> -n aibridge
where <xxxxx> in the pod name will be different for every deployment.
