Smart Wall (Client node)
Smart Wall properties
Info tab
On the Info tab for a Smart Wall definition, you can add and edit Smart Wall properties.
Name |
Description |
| Name |
The name of the Smart Wall definition. Displayed in XProtect Smart Client as the Smart Wall view group name. |
| Description |
A description of the Smart Wall definition. The description is only used internally in XProtect Management Client. |
| Status text |
Display camera and system status information in camera view items. |
| No title bar |
Hide the title bar on all view items on the video wall. |
| Title bar |
Show the title bar on all view items on the video wall. |
On the Presets tab for a Smart Wall definition, you can add and edit Smart Wall presets
XProtect Smart Client 中一個或多個 Smart Wall 監視螢幕的預先定義的版面配置。預設點可決定要顯示哪些攝影機,以及內容會如何呈現在視訊牆的每個監視螢幕上。.
Name |
Description |
| Add New |
Add a preset to your Smart Wall definition. Enter a name and description for the preset. |
| Edit |
Edit the name or description of a preset. |
| Delete |
Delete a preset. |
| Activate |
Apply the preset on the Smart Wall monitors that are configured to use the preset. To apply a preset automatically, you must create a rule that uses the preset. |
On the Layout tab for a Smart Wall definition, you position the monitors, so their positions resemble the mounting of the physical monitors on the video wall. The layout is also used in XProtect Smart Client.
Name |
Description |
Edit |
Adjust the positioning of the monitors. |
Movement |
To move a monitor to a new position, select the monitor and drag it to the desired position, or click one of the arrow buttons to move the monitor in the selected direction. |
Zoom buttons |
Zoom in or out of the Smart Wall layout preview to ensure you position the monitors correctly. |
Name |
The name of the monitor. The name is displayed in XProtect Smart Client. |
Size |
The size of the physical monitor on the video wall. |
Aspect ratio |
The height/width relationship of the physical monitor on the video wall. |
Monitor properties
On the Info tab for a monitor in a Smart Wall preset, you can add monitors and edit the monitor settings.
Name |
Description |
| Name |
| Description |
A description of the monitor. The description is only used internally in the XProtect Management Client. |
| Size |
| Aspect ratio |
| Empty preset |
Defines what should be displayed on a monitor with an empty preset layout when a new Smart Wall preset is triggered or selected in XProtect Smart Client:
| Empty preset item |
Defines what should be displayed in an empty preset item when a new Smart Wall preset is triggered or selected in XProtect Smart Client:
| Element insertion |
Defines how cameras are inserted in the monitor layout when viewed in the XProtect Smart Client:
On the Presets tab for a monitor in a Smart Wall preset, you can edit the view layout and content of the monitor in the selected Smart Wall preset.
Name |
Description |
| Preset |
A list of Smart Wall presets for the selected Smart Wall definition. |
| Edit |
Click Edit to edit the layout and the content of the selected monitor. Double-click a camera to remove it. Click Clear to define a new layout or to exclude the monitor in the Smart Wall preset so the monitor is available for other content not controlled by the Smart Wall preset. Click |
to select the layout you want to use with your monitor, and click
