Upgrade
Your Milestone Husky unit can run with any product variant and version of XProtect VMS determined by the Software License Code (SLC). Your Milestone Husky unit has a preloaded XProtect VMS version ready to be installed, but you can always download and install a newer or older version of XProtect VMS that matches your license. Go to the Milestone Husky owners support and information page (https://www.milestonesys.com/HuskyX8-support/).
You can upgrade your entire system configuration from one product version to another, for example from XProtect 2018 R2 to XProtect 2019 R1 fairly fast and easy. Install the new product on top of the old version without removing the previous version.
For detailed feature descriptions and procedures for configuration and maintenance, see the administrator manual for XProtect VMS.
Remember to apply available VMS optimizations after the upgrade. For more information, see Apply optimizations.
Accessing Husky software updates
Please contact Milestone support for access to upgrades and other related software update packages for your Husky unit.
In some cases, you can access software update packages directly by logging in to My Milestone.
