Ports used by the system
All XProtect components and the ports needed by them are listed below. To ensure, for example, that the firewall blocks only unwanted traffic, you need to specify the ports that the system uses. You should only enable these ports. The lists also include the ports used for local processes.
They are arranged in two groups:
- Server components (services) offer their service on particular ports which is why they need to listen for client requests on these ports. Therefore, these ports need to be opened in the Windows Firewall for inbound and outbound connections
- Client components (clients) initiate connections to particular ports on server components. Therefore, these ports need to be opened for outbound connections. Outbound connections are typically open by default in the Windows Firewall
If nothing else is mentioned, ports for server components must be opened for inbound connections, and ports for client components must be opened for outbound connections.
Do keep in mind that server components can act as clients to other server components. These are not explicitly listed in this doc.
The port numbers are the default numbers, but this can be changed. Contact Milestone support, if you need to change ports that are not configurable through the Management Client.
Each of the following sections list the ports that need to be opened for a particular service. To figure out which ports need to be opened on a particular computer, you need to consider all services running on the computer.
Management Server service and related processes
Port number |
Protocol |
Process |
Connections from... |
Purpose |
80 |
HTTP |
IIS |
All servers and the XProtect Smart Client and the Management Client |
The purpose of port 80 and port 443 is the same. However, which port the VMS uses depends on whether you have used certificates to secure the communication.
443 |
HTTPS |
IIS |
445 |
TCP |
Management Server service |
Management Server Manager. |
Enable Windows Active Directory users to be added to roles. |
6473 |
TCP |
Management Server Manager tray icon, local connection only. |
Showing status and managing the service. |
8080 |
TCP |
Management server |
Local connection only. |
Communication between internal processes on the server. |
9000 | HTTP | Management server | Recording Server services | Web service for internal communication between servers. |
12345 |
TCP |
XProtect Smart Client |
Communication between the system and Matrix recipients. You can change the port number in the Management Client. |
12974 |
TCP |
Windows SNMP Service |
Communication with the SNMP extension agent. Do not use the port for other purposes even if your system does not apply SNMP. In XProtect 2014 systems or older, the port number was 6475. In XProtect 2019 R2 systems and older, the port number was 7475. |
SQL Server service
Port number |
Protocol |
Process |
Purpose |
1433 |
TCP |
SQL Server |
Storing and retrieving configurations via the Identity Provider. |
1433 |
TCP |
SQL Server |
Event Server service |
Storing and retrieving events via the Identity Provider. |
1433 |
TCP |
SQL Server |
Log Server service |
Storing and retrieving log entries via the Identity Provider. |
Data Collector service
Port number |
Protocol |
Process |
Purpose |
7609 |
HTTP |
IIS |
On the management server computer: Data Collector services on all other servers. On other computers: Data Collector service on the Management Server. |
System Monitor. |
Port number |
Protocol |
Process |
Purpose |
1234 |
TCP/UDP |
Event Server Service |
Any server sending generic events to your XProtect system. |
Listening for generic events from external systems or devices. Only if the relevant data source is enabled. |
1235 |
TCP |
9090 |
TCP |
Any system or device that sends analytics events to your XProtect system. |
Listening for analytics events from external systems or devices. Only relevant if the Analytics Events feature is enabled. |
22331 |
TCP |
Configuration, events, alarms, and map data. |
22332 |
WS/WSS HTTP/HTTPS* |
API Gateway and the Management Client |
Event/State Subscription, Events REST API, Websockets Messaging API, and Alarms REST API. |
22333 |
TCP |
MIP Plug-ins and applications. |
MIP messaging. |
*A 403 error will be returned when accessing HTTP to access an HTTPS-only endpoint.
Port number |
Protocol |
Process |
Purpose |
5210 |
TCP |
Recording Server Service |
Failover recording servers. |
Merging of databases after a failover recording server had been running. |
7563 |
TCP |
XProtect Smart Client, Management Client |
Retrieving video and audio streams, PTZ commands. |
8966 |
TCP |
Recording Server Manager tray icon, local connection only. |
9001 | HTTP | Recording Server Service | Management server |
Web service for internal communication between servers. If multiple Recording Server instances are in use, every instance needs its own port. Additional ports will be 9002, 9003, etc. |
11000 |
TCP |
Failover recording servers |
Polling the state of recording servers. |
12975 |
TCP |
Windows SNMP service |
Communication with the SNMP extension agent. Do not use the port for other purposes even if your system does not apply SNMP. In XProtect 2014 systems or older, the port number was 6474. In XProtect 2019 R2 systems and older, the port number was 7474. |
65101 |
UDP |
Recording Server service |
Local connection only |
Listening for event notifications from the drivers. |
In addition to the inbound connections to the Recording Server service listed above, the Recording Server service establishes outbound connections to:
- Cameras
- NVRs
- Remote interconnected sites (Milestone Interconnect ICP)
Failover Server service and Failover Recording Server service
Port number |
Protocol |
Process |
Purpose |
5210 |
TCP |
Failover Recording Server Service |
7474 |
TCP |
Communication with the SNMP extension agent. Do not use the port for other purposes even if your system does not apply SNMP. |
7563 |
TCP |
8844 |
UDP |
Communication between failover recording server services. |
Communication between the servers. |
8966 |
TCP |
Failover Recording Server Manager tray icon, local connection only. |
8967 |
TCP |
Failover Server Service |
Failover Server Manager tray icon, local connection only. |
8990 |
HTTP |
Monitoring the status of the Failover Server service. |
9001 | HTTP | Failover Server Service | Management server | Web service for internal communication between servers. |
In addition to the inbound connections to the Failover Server / Failover Recording Server service listed above, the Failover Server / Failover Recording Server service establishes outbound connections to the regular recorders, cameras, and for Video Push.
Log Server service
Port number |
Protocol |
Process |
Purpose |
22337 |
HTTP |
All XProtect components except for the recording server. |
Write to, read from, and configure the log server. |
This port uses HTTP, but the communication is encrypted with message security which uses the WS-Security specification to secure messages. For more information, see Message Security in WCF.
Mobile Server service
Port number |
Protocol |
Process |
Purpose |
8000 |
TCP |
Mobile Server service |
Mobile Server Manager tray icon, local connection only. |
SysTray application. |
8081 |
HTTP |
Mobile clients, Web clients, and Management Client. |
Sending data streams; video and audio. |
8082 |
HTTPS |
Mobile clients and Web clients. |
40001 - 40099 | HTTP | Mobile Server service | Recording server service |
Mobile Server Video Push. This port range is disabled by default. |
LPR Server service
Port number |
Protocol |
Process |
Purpose |
22334 |
TCP |
LPR Server Service |
Event server |
Retrieving recognized license plates and server status. In order to connect, the Event server must have the LPR plug-in installed. |
22334 |
TCP |
LPR Server Manager tray icon, local connection only. |
SysTray application |
Milestone Open Network Bridge service
Port number |
Protocol |
Process |
Purpose |
580 |
TCP |
Milestone Open Network Bridge Service |
ONVIF clients |
Authentication and requests for video stream configuration. |
554 |
RTSP |
RTSP Service |
ONVIF clients |
Streaming of requested video to ONVIF clients. |
XProtect DLNA Server service
Port number |
Protocol |
Process |
Purpose |
9100 |
HTTP |
DLNA Server Service |
DLNA device |
Device discovery and providing DLNA channels configuration. Requests for video streams. |
9200 |
HTTP |
DLNA device |
Streaming of requested video to DLNA devices. |
XProtect Screen Recorder service
Port number |
Protocol |
Process |
Purpose |
52111 |
TCP |
XProtect Screen Recorder |
Provides video from a monitor. It appears and acts in the same way as a camera on the recording server. You can change the port number in the Management Client. |
XProtect Incident Manager service
Port number |
Protocol |
Process |
Purpose |
80 |
HTTP |
IIS |
443 |
HTTPS |
IIS |
Port number |
Protocol |
Connections to... |
Purpose |
443 |
HTTPS |
The License server that hosts the License Management service. Communication is via https://www.milestonesys.com/ OnlineActivation/ LicenseManagementService.asmx |
Activating licenses. |
Port number |
Protocol |
Connections to... |
Purpose |
80 | HTTP |
Cameras, NVRs, encoders Interconnected sites |
Authentication, configuration, data streams, video, and audio. Login |
443 | HTTPS |
Cameras, NVRs, encoders |
Authentication, configuration, data streams, video, and audio. |
554 | RTSP | Cameras, NVRs, encoders | Data streams, video, and audio. |
7563 | TCP | Interconnected sites | Data streams and events. |
11000 | TCP | Failover recording servers | Polling the state of recording servers. |
40001 – 40099 | HTTP | Mobile Server service |
Port number |
Protocol |
Connections to... |
Purpose |
Port number |
Protocol |
Connections to... |
Purpose |
80 | HTTP | API Gateway and the Management Server | Access the Configuration API from the API Gateway |
443 | HTTPS | API Gateway and the Management Server | Access the Configuration API from the API Gateway |
443 | HTTPS |
Milestone Customer Dashboard via |
Send status, events and error messages from the XProtect system to Milestone Customer Dashboard. |
Log Server service
Port number |
Protocol |
Connections to... |
Purpose |
443 |
HTTP |
Log server |
Forwarding messages to the log server. |
API Gateway
Port number |
Protocol |
Connections to... |
Purpose |
443 |
HTTPS |
Management Server |
RESTful API |
22332 | WS/WSS HTTP/HTTPS* | Management Client | Event/State Subscription, Events REST API, Websockets Messaging API, and Alarms REST API. |
Port number |
Protocol |
Purpose |
80 |
TCP |
Recording servers and failover recording servers |
Authentication, configuration, and data streams; video and audio. |
443 |
HTTPS |
554 |
RTSP |
Data streams; video and audio. |
Port number |
Protocol |
Connections to... |
Purpose |
22337 | HTTP | Log server | Forwarding messages to the log server. |
Only a few camera models are able to establish outbound connections.
XProtect Smart Client, XProtect Management Client, XProtect Mobile server
Port number |
Protocol |
Connections to... |
Purpose |
80 |
HTTP |
API Gateway and Management Server service |
Authentication and other APIs in the API Gateway. |
443 |
HTTPS |
Authentication of basic users when encryption is enabled and other APIs in the API Gateway. |
443 |
HTTPS |
Milestone Systems A/S (doc.milestonesys.com at 52.178.114.226) |
Management Client and Smart Client occasionally check if the online help is available by accessing the help URL. |
7563 |
TCP |
22331 |
TCP |
Alarms. |
XProtect Web Client, XProtect Mobile client
Port number |
Protocol |
Connections to... |
Purpose |
8081 |
HTTP |
XProtect Mobile server |
Retrieving video and audio streams. |
8082 |
HTTPS |
