The Create access control system integration wizard
When you open the wizard, you'll notice that some settings are already filled with default values. These values come from the integration plug-in, which means that the appearance of the wizard will be different depending on the access control system you're integrating with.
  • To start the wizard, in the Management Client, select Access Control in the node tree, right-click, and click Create new.
