Personalized login workarounds for integration version 1.4
Milestone and Software House have committed to maintain compatibility between all possible versions of the XProtect and CCure 9000 systems. This commitment has made it possible to install and integrate between all versions of the integrations which are posted at this link.
The most recent version of CCure 9000 is 3.00.2, this version is fully compatible with the 1.4 version of the XProtect Access integration, and is only supported with the 1.4 version. Personalized login works as expected with integrated systems using CCure 3.00.2 and XProtect Access 1.4.
Below is a list of available workarounds required to maintain compatibility in the following combinations of software versions and feature support.
CCure 9000 Version 2.90 SP6 or 3.00.1 and personalized login.
Change victorwebservice IIS Process Private Memory Limit (KB) to 0.
Change victorwebservice IIS Process Regular Time Interval (minutes) to 60-540.
These two versions of CCure 9000 are both compatible with all supported versions of XProtect. There is only an issue with these versions when the personalized login feature is being used. If this feature is not in use, then there is no need to make any extra modifications.
