XProtect DLNA Server requirements
The computer where you want to install the XProtect DLNA Server component has these requirements:
  • Connected to the same network as the XProtect system
  • Access to the management server
  • Microsoft® .NET Framework 4.7 or higher installed
Ga naar de Milestone-website (https://www.milestonesys.com/systemrequirements/) voor meer informatie over de systeemvereisten voor de verschillende VMS-toepassingen en systeemonderdelen.
