Personalized login
Personalized login is an optional feature of XProtect Access. When a user logs into XProtect Smart Client, personalized login adds a second login into CCure 9000. The user presents valid CCure 9000 credentials, and the Smart Client features will only work with access control hardware, events, and alarms available to that user’s privileges.
Personalized login manages two configurations. First, is the global configuration used by the Management Client. Second, is the personalized configuration used in the Smart Client. Personalized configurations are subsets of the global configuration. This helps ensure accurate event handling, command execution, etc.
Requirements for Personalized login:
  • XPA CCure 9000 integration version 1.1 or higher.
  • CCure 9000 version 2.8 or higher
Enable/disable Personalized login:
Enabling/disabling personalized login for a specific access control plug-in is done in the Management Client. The option is in the General settings menu titled Operator login required:
There are special requirements for personalized login which change slightly based upon the version of CCure 9000. Please read the personalized login workaround topic if you want to use this feature.
