Search for recorded video
Click here to download poster.
When you need to investigate an incident, you can search for the video on the Search tab.
Steps | Action |
Define the time interval. |
Add the cameras with the video you need or choose a view to add all its cameras. |
Select one or more search categories. |
Perfect the search results. For example, if you select the search category Motion, you can restrict the search to look for motion only in specified areas of the video. |
To see a larger preview of the video and its details, click on the search result. |
To view the video, select Play forward. |
Select a search result to export, apply bookmarks, or carry out other actions. To select all search results, select one and press Ctrl+A. |
Select what you want to do. For example, bookmark the video and export it as evidence. |
SC_PPP_SearchForVideo_en-US.pdf
