Add video sequences to the Export list when on the Export tab
Click here to download poster.
The following set of steps describe the initial work needed to export video
If you still need to find the recorded video you want to export, you can find the video and add it to the Export list directly on the Export tab.
| Steps | Action |
Select views and cameras to add them to the Export list. |
Drag to change the start and end time for the export. |
The following set of steps explains how to refine the Export list and create the export.
Cliquez ou scannez :
SC_PPP_AddVideoToExportListOnExportTab_en-US.pdf
