The context-specific timelines
There are several timelines that help you investigate and navigate your recordings in specific contexts.
These context-specific timelines often only have one timeline track and a few to none of the controls available in the main timeline. But when they have timeline controls, they work the same way as the ones on the main timeline.
Timeline | Available from | Purpose | Learn more |
Independent playback | All views tabs | While viewing live video, you can decide to view and go back and forth in the recordings from one of the cameras in your view. | View recorded video independently of the main timeline |
Bookmark | All views tabs | If a sequence of recordings has a bookmark, you can easily find and go to this sequence. | Bookmark window |
Search | The Search tab |
If you have searched for something on the Search tab, the search timeline gives you an overview of recordings matching your search. You can select the different found recordings to view them. |
The search timeline on the Search tab |
Export | The Export tab | If you have selected recordings for export, you can go back and forth in the selected recordings and change the start and end times of the export. | Exporting video, audio, and still images |
