Move hardware troubleshooting
If a move did not succeed, one of the following reasons can be the cause:
Error type |
Troubleshooting |
The recording server is not connected or in failover mode. |
Make sure that the recording server is online. You may need to register it. If the server is in failover mode, wait and try again. |
The recording server is not the latest version. |
Update the recording server so it runs the same version as the management server. |
The recording server could not be found in the configuration. |
Make sure that the recording server has not been removed. |
Updating the configuration or communication with the configuration database failed. |
Make sure that your SQL Server and database are connected and running. |
Stopping the hardware on the current recording server failed |
Maybe another process has locked the recording server, or the recording server is in error mode. Make sure that the recording server is running and try again. |
The hardware does not exist. |
Make sure that the hardware you try to move has not simultaneously been removed from the system by another user. The scenario is quite unlikely. |
The recording server that hardware was moved from is back online, but you chose to ignore it when it was offline. |
Most likely, you have accepted that the old recording server will never get online again when you started the Move Hardware wizard, but during the move, the server came online. Start the wizard again and select No when you are asked to confirm if the server comes online again. |
The source recording storage is unavailable. |
You are trying to move hardware with devices configured with a recording storage which is currently offline. A recording storage is offline if the disk is offline or otherwise unavailable. Make sure that the recording storage is online and try again. |
All recording storages on the target recording server must be available. |
You are trying to move hardware to a recording server where one or more recording storages are currently offline. Make sure that all recording storages on the target recording server are online. A recording storage is offline of the disk is offline or otherwise unavailable. |
