Change LPR server settings
The LPR server must be able to communicate with your management server. To enable this, you specify the IP address or host name of the management server during the installation of the LPR server.
If you need to change the address of the management server, do the following:
  1. Stop the LPR Server service.
  2. In the notification area, right-click the LPR Server Manager icon.
  3. From the menu that appears, select Change settings. The LPR Server service settings window appears.
  4. Specify the new values and click OK.
  5. Restart the LPR Server service.
