Overall Security tab (roles)
Dostupná funkce závisí na vámi používaném systému. Podívejte se na úplný seznam funkcí, který je k dispozici na stránce s přehledem produktu na webu společnosti Milestone (https://www.milestonesys.com/products/software/xprotect-comparison/).
On the Overall Security tab, you set up overall permissions for roles. For every component available in your system, define access permissions for the roles by setting Allow or Deny. When a role is denied access to a component, that component is not visible in the Overall Security tab to a user in that role.
You can define more access permissions for XProtect Corporate than for the other XProtect VMS products. This is because you can only set up differentiated administrator permissions in XProtect Corporate, while you can set up overall permissions for a role that uses XProtect Smart Client, XProtect Web Client, or XProtect Mobile client in all products.
The overall security settings only apply to the current site.
If you associate a user with more than one role and select Deny on a security setting for one role and Allow for another, the Deny permission overrules the Allow permission.
In the following, the descriptions show what happens on each individual permission for the different system components if you select Allow for the relevant role. If you use XProtect Corporate, you can see which settings are available only to your system under each system component.
For every system component or functionality, the full system administrator can use the Allow or Deny check boxes to set up security permissions for the role. Any security permissions that you set up here are set up for the whole system component or functionality. If, for example, you select the Deny check box on Cameras, all cameras added to the system are unavailable for the role. In contrast, if you select the Allow check box, the role can see all cameras added to the system. The result of selecting Allow or Deny on your cameras is that the camera settings on the Device tab then inherit your selections on the Overall Security tab so that either all cameras are either available or unavailable to the particular role.
If you want to set security permissions for individual cameras or similar, you can only set these individual permissions on the tab of the relevant system component or functionality if you have not set any overall permissions for the system component or functionality on the Overall Security tab.
The descriptions below also apply to the permissions that you can configure through the MIP SDKs.
If you want to switch your base license from XProtect Corporate to one of the other products, make sure that you remove all security permissions that are available to only XProtect Corporate. If you do not remove those permissions, you cannot complete the switch.
Security permission |
Description |
Full control |
Enables the permission to manage all security entries on this part of the system. |
Connect |
Enables users to connect to the Management Server. This permission is enabled by default. You can temporarily deny connection permission on roles for maintenance purposes, and then reapply access to the system. This permission must be selected to allow access to the system. |
Read |
This permission is a highly privileged administrative permission that gives significant access rights to the XProtect VMS, including access to sensitive data such as credentials configured in the system. Enables the permission to access a wide range of functionality, including:
It also enables access to:
This permission also reveals some sensitive information to the client:
This permission does not reveal credentials for users of the XProtect VMS. This includes Basic Users, Windows users and users from external IDPs. |
Edit |
Enables the permission to modify data in a wide range of functionality, including:
It also enables users to create, delete, and edit the following:
Enables the permission to configure local IP ranges when configuring the network on the recording server. |
Status API |
Enables the permission to perform queries on the Status API located on the recording server. This means that the role with this permission enabled has access to read the status of the items located on the recording server. |
Manage Federated site hierarchy |
Enables the permission to add and detach the current site to other sites in a federated site hierarchy. If you set this permission to allowed on the child site only, the user can still detach the site from the parent site. |
Backup Configuration |
Enables the permission to create backups of the system configuration using the system's backup and restore functionality. |
Authorize users |
Enables the permission to authorize users when they are asked for a second login in XProtect Smart Client or Management Client. You define if a role requires login authorization on the Info tab. |
Manage security |
Enables the permission to manage permissions for the Management Server. It also enables users to create, delete, and edit the following features:
Description |
Full control |
Edit |
Enables the permission to edit properties on the recording servers, except for network configuration settings that require edit permission on the management server. |
Delete |
Enables the permission to delete recording servers. To do this, you must also give the user delete permissions on:
If any of the devices on the recording server contains evidence locks, you can only delete the recording server if it is offline. |
Manage hardware |
Enables the permission to add hardware on recording servers. |
Manage storage |
Enables the permission to administrate storage containers on recording server, that is, to create, delete, move, and empty storage containers. |
Manage security |
Enables the permission to manage security permissions for recording servers. |
Description |
Full control |
Read |
Enables the permission to see and access failover servers in the Management Client. |
Edit |
Enables the permission to create, update, delete, move, and enable or disable failover servers in the Management Client. |
Manage security |
Enables the permission to manage security permissions for the failover servers. |
Description |
Full control |
Read |
Enables the permission to see and access mobile servers in the Management Client. |
Edit |
Enables the permission to edit and delete mobile servers in the Management Client. |
Manage security |
Enables the permission to manage security permissions for the mobile servers. |
Description |
Full control |
Edit |
Enables the permission to edit properties on hardware. |
Delete |
Enables the permission to delete hardware. If any of the hardware devices contains evidence locks, you can only delete the hardware if the recording server is offline. |
Driver commands |
Enables the permission to send special commands to the drivers and thereby control features and configuration on the device itself. The Driver commands permission is for special developed MIP plug-ins in the clients only. It does not control standard configuration tasks. |
View passwords | Enables the permission to view passwords on hardware devices in the Edit Hardware dialog box. |
Manage security |
Enables the permission to manage security permissions for the hardware. |
Description |
Full control |
Read |
Enables the permission to view camera devices in the clients and the Management Client. |
Edit |
Enables the permission to edit properties for cameras in the Management Client. It also enables users to enable or disable a camera. |
View live |
Enables the permission to view live video from cameras in the clients and the Management Client. |
View restricted live |
Enables the permission to view live restricted video from cameras in the clients and the Management Client. |
Playback |
Enables the permission to play back recorded video from cameras in all clients. |
Playback restricted recordings |
Enables the permission to play back recorded restricted video from cameras in all clients. |
Retrieve remote recordings |
Enables the permission to retrieve recordings in the clients from cameras on remotes sites or from edge storages on cameras. |
Read sequences |
Enables the permission to read the sequence information related to, for example, playing back recorded video in the clients. |
Smart search |
Enables the permission to use the Smart search function in the clients. |
Export |
Enables the permission to export recordings from the clients. |
Create bookmarks |
Enables the permission to create bookmarks in recorded and live video in the clients. |
Read bookmarks |
Enables the permission to search for and read bookmark details in the clients. |
Edit bookmarks |
Enables the permission to edit bookmarks in the clients. |
Delete bookmarks |
Enables the permission to delete bookmarks in the clients. |
Create and extend evidence locks |
Enables the permission to create and extend evidence locks in the clients. |
Read evidence locks |
Enables the permission to search and read evidence locks in the clients. |
Delete and reduce evidence locks |
Enables the permission to delete or reduce evidence locks in the clients. |
Create and extend live and playback restrictions |
Enables the permission to create and extend restrictions in the clients. |
Read live and playback restrictions |
Enables the permission to see a list of existing restrictions in the clients. |
Delete and reduce live and playback restrictions |
Enables the permission to delete and reduce restrictions in the clients. |
Start manual recording |
Enables the permission to start manual recording of video in the clients. |
Stop manual recording |
Enables the permission to stop manual recording of video in the clients. |
AUX commands |
Enables the permission to use auxiliary (AUX) commands on the camera from the clients. AUX commands offer users the control of, for example, wipers on a camera connected via a video encoder. Camera-associated devices connected via auxiliary connections are controlled from the client. |
Manual PTZ |
Enables the permission to use PTZ functions on PTZ cameras in the clients and the Management Client. |
Activate PTZ presets or patrolling profiles |
Enables the permission to move PTZ cameras to preset positions, start and stop patrolling profiles, and pause a patrolling in the clients and the Management Client. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
Manage PTZ presets or patrolling profiles |
Enables the permission to add, edit, and delete PTZ presets and patrolling profiles on PTZ cameras in the clients and the Management Client. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
Lock/unlock PTZ presets |
Enables the permission to lock and unlock PTZ presets in the Management Client. This prevents or allows other users from changing preset positions in the clients and in the Management Client. |
Reserve PTZ sessions |
Enables the permission to set PTZ cameras in reserved PTZ session mode in the clients and the Management Client. In a reserved PTZ session, other users with higher PTZ priority are not able to take over the control. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
Release PTZ sessions |
Enables the permission to release other users' PTZ sessions from the Management Client. You can always release your own PTZ sessions - without this permission. |
Delete recordings |
Enables the permission to delete stored video recordings from the system via the Management Client. |
Lift privacy masks |
Enables the permission to temporarily lift privacy masks in XProtect Smart Client. It also enables the permission to authorize other XProtect Smart Client users to lift privacy masks. Lifting privacy masks only applies to privacy masks configured as liftable privacy masks in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for the camera. |
Description |
Full control |
Read |
Enables the permission to view microphone devices in the clients and the Management Client. |
Edit |
Enables the permission to edit microphone properties in the Management Client. It also allows users to enable or disable microphones. |
Listen live |
Enables the permission to listen to live audio from speakers in the clients and the Management Client. |
Listen restricted live audio |
Enables the permission to listen to live restricted audio from speakers in the clients and the Management Client. |
Playback |
Enables the permission to play back recorded audio from microphones in the clients. |
Enables the permission to play back recorded restricted audio from microphones in the clients. |
Enables the permission to retrieve recordings in the clients from microphones on remotes sites or from edge storages on cameras. |
Read sequences |
Enables the permission to read the sequence information related to, for example, the Playback tab in the clients. |
Export |
Create bookmarks |
Enables the permission to create bookmarks in the clients. |
Read bookmarks |
Edit bookmarks |
Delete bookmarks |
Enables the permission to create or extend evidence locks in the clients. |
Enables the permission to search and read evidence lock details in the clients. |
Enables the permission to create and extend restrictions on microphones in the clients. |
Enables the permission to see a list of existing restrictions on microphones in the clients. |
Enables the permission to delete and reduce restrictions on microphones in the clients. |
Enables the permission to start manual recording of audio in the clients. |
Enables the permission to stop manual recording of audio in the clients. |
Delete recordings |
Enables the permission to delete stored recordings from the system. |
Manage security |
Enables the permission to manage security permissions in the Management Client for microphones. |
Description |
Full control |
Read |
Enables the permission to view speaker devices in the clients and the Management Client. |
Edit |
Enables the permission to edit properties for speakers in the Management Client. It also allows users to enable or disable speakers. |
Listen live |
Speak |
Enables the permission to speak through the speakers in the clients. |
Playback |
Enables the permission to play back recorded audio from speakers in the clients. |
Enables the permission to retrieve recordings in the clients from speakers on remotes sites or from edge storages on cameras. |
Read sequences |
Enables the permission to use the Sequences feature while browsing recorded audio from speakers in the clients. |
Export |
Enables the permission to export recorded audio from speakers in the clients. |
Create bookmarks |
Read bookmarks |
Edit bookmarks |
Delete bookmarks |
Enables the permission to create or extend evidence locks to protect recorded audio in the clients. |
Enables the permission to view recorded audio protected by evidence locks in the clients. |
Enables the permission to delete or reduce evidence locks on protected audio in the clients. |
Enables the permission to create and extend restrictions on speakers in the clients. |
Enables the permission to see a list of existing restrictions on speakers in the clients. |
Enables the permission to delete and reduce restrictions on speakers in the clients. |
Delete recordings |
Manage security |
Enables the permission to manage security permissions in the Management Client for speakers. |
Description |
Full control |
Read |
Enables the permission to receive metadata in the clients. |
Edit |
Enables the permission to edit metadata properties in the Management Client. It also allows users to enable or disable metadata devices. |
Live |
Enables the permission to receive live metadata from metadata devices in the clients. |
View restricted live | Enables the permission to receive live restricted metadata from metadata devices in the clients. |
Playback |
Enables the permission to play back recorded data from metadata devices in the clients. |
Playback restricted recordings | Enables the permission to play back restricted recorded data from metadata devices in the clients. |
Enables the permission to retrieve recordings in the clients from metadata devices on remotes sites or from edge storages on cameras. |
Read sequences |
Export |
Enables the permission to export recordings in the clients. |
Enables the permission to create evidence locks in the clients. |
Enables the permission to view evidence locks in the clients. |
Enables the permission to create and extend restrictions on metadata in the clients. |
Enables the permission to see a list of existing restrictions on metadata in the clients. |
Enables the permission to delete and reduce restrictions on metadata in the clients. |
Enables the permission to start manual recording of metadata in the clients. |
Enables the permission to stop manual recording of metadata in the clients. |
Delete recordings |
Manage security |
Enables the permission to manage security permissions in the Management Client for metadata. |
Description |
Full control |
Read |
Enables the permission to view input devices in the clients and the Management Client. |
Edit |
Enables the permission to edit properties for input devices in the Management Client. It also enables users to enable or disable an input device. |
Manage security |
Enables the permission to manage security permissions in the Management Client for input devices. |
Description |
Full control |
Read |
Enables the permission to view output devices in the clients. |
Edit |
Enables the permission to edit properties for output devices in the Management Client. It also enables users to enable or disable an output device. |
Activate |
Enables the permission to activate outputs in the clients. |
Manage security |
Enables the permission to manage security permissions in the Management Client for output devices. |
Description |
Full control |
Enables the permission to manage all security permissions in XProtect Management Client. |
Read |
Enables the permission to view a video wall in XProtect Smart Client. |
Edit |
Enables the permission to edit properties for the Smart Wall definition in XProtect Management Client. |
Delete |
Enables the permission to delete existing Smart Wall definitions in XProtect Management Client. |
Operate |
Enables the permission to activate and modify Smart Wall definitions, for example to change and activate presets or apply cameras on views in XProtect Smart Client and in XProtect Management Client. You can associate Operate with time profiles that define when the user permission applies. |
Create Smart Wall |
Enables the permission to create new Smart Wall definitions in XProtect Management Client. |
Manage security |
Enables the permission to manage security permissions in XProtect Management Client for the Smart Wall definition. |
Playback |
Enables the permission to play back recorded data from a video wall in XProtect Smart Client. You can associate Playback with time profiles that define when the user permission applies. |
Description |
Full control |
Read |
Enables the permission to view View Groups in the clients and in the Management Client. View groups are created in the Management Client. |
Edit |
Enables the permission to edit properties on the View Groups in the Management Client. |
Delete |
Enables the permission to delete View Groups in the Management Client. |
Operate |
Enables the permission to use View Groups in XProtect Smart Client, that is, to create and delete subgroups and views. |
Create view group |
Enables the permission to create View Groups in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for View Groups. |
Description |
Full control |
Read |
Enables the permission to view user-defined events in the clients. |
Edit |
Enables the permission to edit properties on user-defined events in the Management Client. |
Delete |
Enables the permission to delete user-defined events in the Management Client. |
Trigger |
Enables the permission to trigger user-defined events in the clients. |
Manage security |
Enables the permission to manage security permissions in the Management Client for user-defined events. |
Create user-defined event |
Enables the permission to create new user-defined events in the Management Client. |
Description |
Full control |
Read |
Enables the permission to view analytics events in the Management Client. |
Edit |
Enables the permission to edit properties on analytics events in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for analytics events. |
Description |
Full control |
Read |
Enables the permission to view generic events in the clients and the Management Client. |
Edit |
Enables the permission to edit properties on generic events in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for generic events. |
Description |
Full control |
Read |
Enables the permission to select and send video to the Matrix recipient from the clients. |
Edit |
Enables the permission to edit properties for a Matrix in the Management Client. |
Delete |
Enables the permission to delete a Matrix in the Management Client. |
Create Matrix |
Enables the permission to create a new Matrix in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for all Matrix's. |
Description |
Full control |
Read |
Enables the permission to view existing rules in the Management Client. |
Edit |
Enables the permission to edit properties for rules and to define rule behavior in the Management Client. It also requires that the user has read permissions on all the devices that are impacted by the rule. |
Delete |
Enables the permission to delete rules from the Management Client. It also requires that the user has read permissions on all devices that are impacted by the rule. |
Create rule |
Enables the permission to create new rules in the Management Client. It also requires that the user has read permissions on all devices that are impacted by the rule. |
Manage security |
Enables the permission to manage security permissions in the Management Client for all rules. |
Description |
Full control |
Read |
Enables the permission to view other sites in the Management Client. Connected sites are connected via Milestone Federated Architecture. To edit properties, you need Edit permissions on the Management Server on each site. |
Manage security |
Enables the permission to manage security permissions on all sites. |
Description |
Full control |
Read |
Enables the permission to view system monitors in XProtect Smart Client. |
Edit |
Enables the permission to edit properties for system monitors in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for all system monitors. |
Description |
Full control |
Manage |
Enables the permission to manage alarms in the Smart Client. For example, changing priorities of alarms, re-assigning alarms to other users, acknowledging alarms, changing the alarm state of multiple alarms (for example from New to Assigned). To edit alarm settings, you also need the Edit alarm settings permission. Only when you set this to allowed does the Alarms and Events tab in the Options dialog appear. |
View |
Enables the permission to view the Alarm Manager tab in XProtect Smart Client and retrieve alarms and alarm settings through the API. To view alarms in XProtect Smart Client, you must enable the View permission for at least one alarm definition. You view alarms from third-party solutions by default. |
Disable alarms |
Enables the permission to disable alarms. |
Receive notifications | Enables the permission to receive notifications about alarms in XProtect Mobile clients and XProtect Web Client. |
Manage security |
Enables the permission to manage security permissions for alarms. |
Edit alarm settings | Enables the permission to edit alarm definitions, alarm states, alarm categories, alarm sounds, alarm retention, and event retention. To edit alarm settings, you also need the Manage permission. |
Description |
Full control |
View |
Enables the permission to view alarm definitions, alarm states, alarm categories, alarm sounds, alarm retention, and event retention. |
Write |
Enables the View permission. |
Manage security |
Enables the permission to manage security permissions for alarm definitions. |
Description |
Full control |
Read |
Enables the permission to view the Metadata Use functionality in Management Client and its related settings, but does not enable the permission to change the settings. |
Edit the metadata search configuration |
Enables the permission to enable or disable metadata search categories, for example metadata for people or vehicles, in the Management Client. |
Manage security |
Enables the permission to manage security permissions for metadata searches. |
Description |
Read public searches | Enables the permission to view and open saved public searches in XProtect Smart Client. |
Create public searches | Enables the permission to save newly configured searches as public searches in XProtect Smart Client. |
Edit public searches | Enables the permission to edit the details or the configuration of saved public searches in XProtect Smart Client, for example the name, description, cameras, and search categories. |
Delete public searches | Enables the permission to delete saved public searches. |
Manage security |
Enables the permission to manage security permissions in the Management Client for search. |
Description |
Full control |
Read system log entries | Enables the permission to see system log entries. |
Read audit log entries | Enables the permission to see audit log entries. |
Read rule-triggered log entries | Enables the permission to see rule-triggered log entries. |
Read log configuration | Enables the permission to read log settings in Tools > Options > Server Logs. |
Update log configuration | Enables the permission to change log settings in Tools > Options > Server Logs. |
Manage security |
Description |
Full control |
Read |
Enables the permission to view properties for the Transaction sources in the Management Client. |
Edit |
Enables the permission to edit properties for the Transaction sources in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for all Transaction sources. |
Description |
Full control |
Read |
Enables the permission to view properties for the Transaction definitions in the Management Client. |
Edit |
Enables the permission to edit properties for the Transaction definitions in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for all Transaction definitions. |
Description |
Full control |
Edit |
Enables the permission to edit properties for the Access Control systems in the Management Client. |
Use access control | Allows the user to use any access control-related features in the clients. |
View cardholders list | Allows the user to view the cardholders list on the Access Control tab in the clients. |
Receive notifications | Allows the user to receive notifications about access requests in the clients. |
Manage security |
Enables the permission to manage security permissions for all Access Control systems. |
Description |
Full control |
Manage |
Currently not in use. |
View |
Allows the user to use the Privacy Blur feature in XProtect Smart Client. |
Manage security | Currently not in use. |
Description |
Full control |
Manage | Enables the user to create, edit, delete sticky notes in XProtect Smart Client. |
View | Enables the user to see the sticky notes in XProtect Smart Client. |
Description |
Full control |
Manage | Currently not in use. |
View | Enables the user to use Multiroom Audio in XProtect Smart Client. |
If your system runs with XProtect LPR, specify the following permissions for the user:
Description |
Full control |
View the LPR tab in client applications |
Enables the permission to use XProtect LPR features in XProtect Smart Client. |
Manage LPR |
Enables the permission to:
View the LPR node in Management Client |
Manage security |
Enables the permission to manage security permissions in the Management Client for LPR. |
Description |
Full control |
Edit |
Enables the permission to edit properties for webhooks in the Management Client. |
Read |
Enables the permission to view properties for webhooks in the Management Client. |
Manage security |
Enables the permission to manage security permissions in the Management Client for all webhooks. |
Through the MIP SDK, a third-party vendor can develop custom plug-ins for your system, for example, integration to external access control systems or similar functionality.
