XProtect Access (explained)
Milestone 已開發了許多擴充。擴充是指可以透過額外專門功能延伸 XProtect 視訊管理軟體功能的產品。
XProtect Access is an extension of XProtect. It enables customers to integrate their access control systems with XProtect if a dedicated XProtect plug-in exists for that access control system.
To use this extension, you must purchase:
- 1 (one) base license for each XProtect system you want to use with XProtect Access.
- 1 (one) door license for each door you want to control through XProtect.
XProtect Access includes:
- A common operator user interface for access control systems in XProtect Smart Client.
- Powerful integration of access control systems.
- Live monitoring of events at access points.
- Operator-assisted access requests.
- Integrations with maps.
- Alarm definitions for access control events.
- Investigation of events at access points.
- Centralized overview and control of door states.
- Cardholder information and management.
Whenever a user in XProtect Smart Client takes any access-related action, such as opening a door or denying entry, the system records it in the Audit log.
