Add video sequences to the Export list when on the Search tab
Click here to download poster.
The following set of steps describe the initial work needed to export video
If you already found the recorded video you want to export while searching on the Search tab, you can add it to the Export list this way:
Steps | Action |
Select each search result that you want to export. |
Add the selected video sequences to the Export list. |
The following set of steps explains how to refine the Export list and create the export.
Şunu tıklayın veya tarayın:
SC_PPP_AddVideoToExportListOnSearchTab_en-US.pdf
