Using ONVIF clients to view video streams
ONVIF clients can be many different things, ranging from advanced custom surveillance systems to basic media players.
If your have applied a permanent privacy mask on your video, you won't be able to stream the video from an ONVIF client.
This section provides examples of how to connect to the Milestone Open Network Bridge.
