Backup and restore fail and problem scenarios (explained)
If, after your last system configuration backup, you have moved the event server or other registered services such as the log server, you must select which registered service configuration you want for the new system. You can decide to keep the new configuration after the system is restored to the old version. You decide by looking at the host names of the services.
If your restore of the system configuration fails because the event server is not located at the specified destination (for example, if you have chosen the old registered service setup), do another restore.
If you are restoring a configuration backup and entering a system configuration password that is incorrect, you must provide the system configuration password that was valid at the time when the backup was created.
Lütfen yanıtınıza herhangi bir kişisel veriyi dâhil etmeyin, örneğin ad, e-posta, telefon numarası vb. Kişisel veri sağlarsanız, Milestone bu türdeki kişisel verileri Gizlilik Politikamız doğrultusunda işleyeceksiniz. Kişisel verileriniz Gizlilik Politikası doğrultusunda mümkün olan en kısa sürede silinecektir.
