Complete the Husky Assistant Wizard
Have your Milestone XProtect license file ready if you want to install Milestone XProtect VMS on your Husky IVO unit as part of completing the Husky Assistant wizard.
You can complete the Husky Assistant wizard without installing Milestone XProtect but XProtect must then be manually installed later.
Husky Assistant now starts automatically. This wizard helps you check, select, and configure your Milestone Husky IVO with:
  • Computer name and domain or workgroup
  • Data storage drive detection
  • Data storage configuration
  • Milestone XProtect version
  • Additional system optimizations
To complete the wizard:
  1. Select your preferred language and click Next.
  2. Click Computer name / Domain changes to configure computer name and domain or workgroup settings.
    When completed, Windows will require a restart to apply the changes.
  3. Restart Windows and wait for Windows to boot.
    The Husky Assistant restarts. Click Next.
  4. Because you have already configured the name and domain setting, click Next.
  5. Make sure that all the hard drives are detected and click Next.
  6. Select the preferred RAID configuration to match your storage requirement. Click Next.
    The Advanced option is to manually configure the RAID using the RAID storage manager application.
  7. You have different options when selecting the Milestone XProtect version to install. Select one of these options:
    • Check if the pre-loaded XProtect version is the version that you want to install. If yes, select Install pre-loaded Milestone XProtect and click Next.
    • If you want to install an XProtect version different than the pre-loaded one:
      1. Choose Select Milestone XProtect installer.
      2. Download the XProtect version that you prefer from the Milestone website.
      3. Click Browse to select the downloaded installer file and click Next.
    • To use your unit as a recording server in an already existing Milestone XProtect system:
      1. Select Download and install a recording server from an existing Management Server and click Next.
      2. Provide the IP address of the computer with the management server installed, and credentials.
      3. Click Next. The installation files for the recording server will be downloaded from the management server later.
    • Select Do not install Milestone XProtect now if you want to install Milestone XProtect later without the aid from Husky Assistant.
      Remember to apply optimizations in Husky Assistant after installation.
  8. The Review and apply the configuration window appears. Verify your selections and click Apply to start the process.
    The system automatically starts the Milestone XProtect installation. Дополнительную информацию см. в руководстве администратора для XProtect VMS.
After you have completed the Husky Assistant wizard, the application changes and Husky Assistant now serves as an application that helps you configure, maintain, and see the status of your Milestone Husky system. Find the Husky Assistant shortcut on the Windows desktop.
