MIP SDK upgrade error 2803
When you upgrade the integration from an older version to a newer version, one of the components that is required to upgrade is the Milestone MIPSDK. During the upgrade process, the MIPSDK installation wizard can create an error if services or applications that are using the MIPSDK files are still running because they are being upgraded.
Milestone recommends that you continue the upgrade process, and restart all services and applications afterward to ensure they are using the newest versions of the required MIPSDK files. Read the Milestone knowledge base troubleshooting article for more information.
