Questa pagina non è ancora disponibile nella lingua richiesta.
Backup and restore fail and problem scenarios (explained)
If, after your last system configuration backup, you have moved the event server or other registered services such as the log server, you must select which registered service configuration you want for the new system. You can decide to keep the new configuration after the system is restored to the old version. You decide by looking at the host names of the services.
If your restore of the system configuration fails because the event server is not located at the specified destination (for example, if you have chosen the old registered service setup), do another restore.
If you are restoring a configuration backup and entering a system configuration password that is incorrect, you must provide the system configuration password that was valid at the time when the backup was created.
Non includere eventuali dati personali nella risposta, come nome, indirizzo e-mail, numero di telefono, ecc. Nel caso in cui vengano forniti eventuali dati personali, Milestone li tratterà in conformità con la nostra Informativa sulla privacy. I dati personali verranno eliminati non appena possibile in conformità con la nostra Informativa sulla privacy.
