RMA process
Step | Stakeholder | Actions | Milestone Resources |
1 |
Milestone Support
Agree on the type of RMA:
2a |
Milestone Reseller
Request a purchase for a replacement unit or component corresponding to the agreed replacement. The purchase request is sent to the Milestone Distributor serving the Milestone Reseller. The purchase order shall include the RMA number from Milestone | |
2b |
Milestone Region: Rest of World |
Request a purchase order for a replacement unit or component corresponding to the agreed replacement and is sent to the Milestone Distributor serving the Milestone Reseller. The Milestone Distributor will issue a purchase order and shall include the RMA number from Milestone |
3 | Milestone Distributor | Issue a purchase order for a replacement unit or component corresponding to the agreed replacement. The purchase order shall include the RMA number from Milestone | Milestone Store |
4 | Milestone |
Dispatch a replacement unit or component corresponding to the purchase order. |
5 | Milestone Reseller |
Upon reception of the replacement product or component, unpack and install it with the End-customer. The replacement can be pre-loaded with a different XProtect VMS release version than the original unit, whereby the software on the replacement unit may require to be upgraded or downgraded to match the End-customers installation and XProtect VMS license. |
Getting Started Guide
6 | Milestone Reseller | Package the failed unit or component in the shipment packaging in which the replacement unit or component was received. Send the failed unit or component to Milestone within five business days after the reception of the replacement unit or component. Use the freight service prepaid by Milestone. | |
7 | Milestone PSSS | Once Milestone has received and validated the failed unit or component, Milestone will issue a credit note on the purchase of the replacement unit. For more information on the validation process, see Validation of received products. | |
8 | Milestone Distributor | Receive credit note. |
