Take snapshots from search results
To save and share still images from your search results, you can take multiple snapshotsClosedAn instant capture of a frame of video at a given time. at the same time.
Steps:
  1. When you have performed your search, hover over the search results, one by one, and select the check box .
  2. In the blue action bar, click and select Create snapshot. A progress bar informs you when the snapshots are created.
  3. To locate the snapshots on your computer, go to the location that is specified in the Settings dialog > Application > Path to snapshots.
