Change password (basic authentication only)
If you log in as a basic user (Basic authentication) and your XProtect VMS system uses version 2021 R1 or later, you can change your password.
If you choose a different authentication method, only your system administrator can change your password. Changing your password often increases the security of your XProtect VMS system.
Start XProtect Smart Client. The login window is displayed.
Specify your login information. In the Authentication list, select Basic authentication. A link with the text Change password appears.
Select Change password.
Follow the instructions and save your changes.
Log in to XProtect Smart Client using your new password.
