Troubleshooting: Attempts to add a web page to a view
These scenarios can occur when you add a web page to a view item:
The web page uses scripts that are not supported by the browser used to render the web page. Changing the Display mode in the web page properties might resolve the issue.
Have you set Display mode to Compatibility? Only Compatibility mode supports scripting.
Have you used the correct syntax in your HTML code?
Is HTML scripting enabled in XProtect Management Client or in the Client.exe.config file?
Does the intended audience have the user permissions to access certain cameras, views, features, or tabs in XProtect Smart Client?
