Server Logs node
System logs (tab)
Each row in a log represents a log entry. A log entry contains a number of information fields:
| Name | Description |
| Log level | Info, warning, or error. |
| Local time | Timestamped in the local time of your system's server. |
| Message text | The identification number for the logged incident. |
| Category | The type of logged incident. |
| Source type | The type of equipment on which the logged incident occurred, for example, server or device. |
| Source name | The name of the equipment on which the logged incident occurred. |
| Event type | The type of event represented by the logged incident. |
Audit logs (tab)
| Message text | Shows a description of the logged incident. |
| Permission | The information about whether the remote user action was allowed (granted) or not. |
| User | The user name of the remote user causing the logged incident. |
| User location | The IP address or host name of the computer from which the remote user caused the logged incident. |
Rule-triggered logs (tab)
| Rule name | The name of the rule triggering the log entry. |
| Service name | The name of the service on which the logged incident occurred. |
