Delete a camera or server tile on the System monitor dashboard
If you no longer need to monitor the hardware represented by a tile, you can delete the tile.
                                    In the Site Navigation pane, select System Dashboard > System Monitor.
- In the System Monitor window, select Customize.
- In the Customize dashboard window that opens, select the tile you want to change under Server tiles or Camera tiles.
- Select Delete.
