Give users permission to lift privacy masks
By default, no users have permissions to lift privacy masks in XProtect Smart Client.
To enable/disable the permission:
- In the Site Navigation pane, select Security and then select Roles.
 - Select the role that you want to give permission to lift privacy masks.
 - On the Overall Security tab, select Cameras.
 - Select the Allow check box for the Lift privacy masks permission.
Users that you assign to this role, can lift privacy masks configured as liftable masks for himself/herself as well as authorize the lift for other XProtect Smart Client users.
