Enable and disable motion detection
Specify the default setting of motion detection for cameras
- On the Tools menu, click Options.
 - On the General tab, under When adding new camera devices automatically enable, select the Motion detection check box.
Enable or disable motion detection for a specific camera
- In the Site Navigation pane, select Devices and then select Cameras.
 - Select the relevant camera in the Overview pane.
 - On the Motion tab tab, select or clear the Motion detection check box.
When you disable motion detection for a camera, motion detection-related rules for the camera do not work.
