License types
There are several license types in the XProtect licensing system.
Base licenses
As a minimum, you have a base license for one of the XProtect VMS products. You may also have one or more base licenses for XProtect extensions.
Device licenses
As a minimum, you have several device licenses. Generally, you need one device license per hardware device with a camera that you want to add to your system. But this can differ from one hardware device to another and depending on the hardware device being a Milestone supported hardware device or not. For more information, see Supported hardware devices and Unsupported hardware devices.
If you want to use the video push feature in XProtect Mobile, you also need one device license per mobile device or tablet that should be able to push video to your system.
Device licenses are not required for speakers, microphones, or input and output devices attached to your cameras.
Generally, you need one device license per hardware device with a camera that you want to add to your system. But a few supported hardware devices require more than one device license. You can see how many device licenses your hardware devices require, in the list of supported hardware on the Milestone website (https://www.milestonesys.com/support/tools-and-references/supported-devices/).
For video encoders with up to 16 channels, you need only one device license per video encoder IP address. A video encoder can have one or more IP addresses.
However, if the video encoder has more than 16 channels, one device license per activated camera on the video encoder is required - also for the first 16 activated cameras.
An unsupported hardware device requires one device license per activated camera using a video channel.
Unsupported hardware devices do not appear in the list of supported hardware on the Milestone website (https://www.milestonesys.com/support/tools-and-references/supported-devices/).
Camera licenses for Milestone Interconnect™
To run Milestone Interconnect, you need Milestone Interconnect camera licenses on your central site to view video from hardware devices on remote sites. The number of required Milestone Interconnect camera licenses depends on the streaming activity on the remote sites that you want to receive data from. The requirement is one license per stream. Only XProtect Corporate can act as a central site.
Licenses for XProtect extensions
Most XProtect extensions require additional license types. The software license file also includes information about your extension licenses. Some extensions have their own separate software license files.
- XProtect Access (see XProtect Access licenses)
- XProtect LPR (see XProtect LPR licenses)
- XProtect Transact (see Before you start)
XProtect Smart Wall requires the following video wall-related licenses:
- A base license for XProtect Smart Wall that covers an unrestricted number of monitors displaying video on a video wall
Use of XProtect Smart Wall is only supported in these products:
XProtect Corporate - a base license for XProtect Smart Wall is included in the base license
XProtect Expert - purchase a base license for XProtect Smart Wall separately
XProtect Incident Manager requires the following licenses:
A base license that covers the full use of XProtect Incident Manager
Use of XProtect Incident Manager is only supported in the following VMS products and versions:
XProtect Corporate 2022 R2 and later: a base license for XProtect Incident Manager is included
XProtect Expert, XProtect Professional+, and XProtect Express+ 2022 R3 and later: purchase a base license for XProtect Incident Manager separately
