Layers on smart map
You can turn layers on and off on your smart map depending on what you want to see.
A smart map has multiple layers. Each layer contains different elements.
You can hide the elements on a smart map layer. This feature is useful when you want to focus on a specific element or simplify the display on the smart map.
| Layer | Elements |
| System elements | Cameras and other devices. Links and locations. |
| Custom overlays | Bitmap images, CAD drawings, and shapefiles. |
| Geographic backgrounds | The basic world map or one of the following services:
Bing Maps and Google Maps are available as geographic backgrounds only if your system administrator has enabled them in XProtect Management Client. For more information, see Geographic backgrounds.
