Manually activate events
You can manually activate an event. There is no confirmation when you have activated an event. The list of events
A predefined incident occurring on the surveillance system; used by the surveillance system for triggering actions. Depending on surveillance system configuration, events may be caused by input from external sensors, by detected motion, by data received from other applications, or manually through user input. The occurrence of an event could, for example, be used for making a camera record with a particular frame rate, for activating outputs, for sending e-mails, or for a combination thereof. you can select is grouped by event server, and the camera or device that the event is associated with.
- In live mode, expand the Event pane, then click Activate.
Global events appear under the relevant event server. If an event server is listed with a red icon, it is unavailable and you cannot activate events on it.
