The main timeline and edge retrieval
If you select a camera with edge storage, the light and medium gray colors on the timeline tracks show whether the recordings on an edge storage are retrieved to your local recording server:
The light gray color with the legend Unknown indicates that the recordings are not retrieved. Before a retrieval attempt, you can’t see if there are recordings to retrieve from the edge storage.
The medium gray color with the legend Data requested indicates that retrieval is in process.
When the recordings are retrieved, the timeline tracks use the same colors as for all your recordings. See Color legend.
