Recordings from edge storage and Milestone Interconnect
There are two types of cameras with edge storage:
Cameras with memory cards on which the recordings are saved.
Interconnected cameras that are part of another XProtect VMS installation and that you have access to through Milestone Interconnect™.
When you have the necessary user permissions, you can manually retrieve recordings from cameras with edge storage. Retrieval of recordings can also happen automatically through rules defined by your XProtect VMS administrator.
