XProtect DLNA Server requirements
The computer where you want to install the XProtect DLNA Server component has these requirements:
  • Connected to the same network as the XProtect system
  • Access to the management server
  • Microsoft® .NET Framework 4.7 or higher installed
For information about the system requirements for the various VMS applications and system components, go to the Milestone website (https://www.milestonesys.com/systemrequirements/).
