Copy a Smart Client profile
If you have a Smart Client profile with complicated settings or permissions and need a similar profile, it might be easier to copy an already existing profile and make minor adjustments to the copy than to creating a new profile from scratch.
- Click Smart Client Profiles, right-click the profile in the Overview pane, select Copy Smart Client Profile.
 - In the dialog box that appears, give the copied profile a new unique name and description. Click OK.
 - In the Overview pane, click the profile you just created to configure it. This is done by adjusting settings on one, more, or all of the available tabs. Click OK.
