Doors and Associated Cameras tab (Access Control)
Use this tab to link door access points with cameras, microphones, and speakers.
You must assign cameras to door access points during the integration setup, but you can change them later.
Microphones and speakers are automatically linked through their associated cameras.
Name |
Description |
Doors |
Lists the available door access points defined in the access control system, grouped by door. For an easier navigation to the relevant doors, you can filter on the doors in your access control system with the dropdown list box at the top. Enabled: Licensed doors are enabled by default. You can disable a door to free up a license. License: Shows if a door is licensed or if the license has expired. The field is empty when the door is disabled. Remove: Click Remove to remove a camera from an access point. If you remove all cameras, the check box for associated cameras is automatically cleared. |
Cameras |
Lists the cameras configured in the XProtect system. Select a camera from the list and drag and drop it at the relevant access point to associate the access point with the camera. |
