Access Request Notification tab (Access Control)
You can customize how your access request notifications are displayed in XProtect Smart Client when a given event is triggered.
Name |
Description |
| Name |
Enter a name for the access request notification. |
| Add Access Request Notification |
Click to add and define access request notifications. To delete a notification, click X on the right-hand side. If you log into the parent site using XProtect Smart Client in a Milestone Federated Architecture, you also see access request notifications from the child sites. |
| Access request notification details |
Specify the cameras, microphones, or speakers that are displayed in the access request notifications when a given event occurs. You can also specify the sound you want to use to alert the user when the notification is displayed. |
| Add command |
Select the commands to display as buttons in access request notification windows in XProtect Smart Client.
To delete a command, click X on the right-hand side. |
