Patrolling profiles and manual patrolling (explained)
Patruljeringsprofiler er definitionerne for, hvordan patruljering skal finde sted. Dette inkluderer rækkefølgen for de forudindstillede positioner, kameraet skal bevæge sig til, og hvor længe det skal blive på hver position. Du kan oprette et ubegrænset antal patruljeringsprofiler og bruge dem i dine regler Du kan for eksempel oprette en regel, der angiver, at en patruljeringsprofil skal bruges i åbningstiden om dagen, og en anden skal bruges om natten.
Manual patrolling
Before you apply a patrolling profile in a rule, for example, you can test the patrolling profile with manual patrolling. You can also use manual patrolling to take over patrolling from another user or from a rule-activated patrolling, provided that you have a higher PTZ priority.
If the camera is already patrolling or controlled by another user, you can only start manual patrolling if you have a higher priority.
If you start a manual patrolling while the camera runs a rule-activated system patrolling, the system resumes this patrolling when you stop your manual patrolling. If another user runs a manual patrolling, but you have a higher priority and start your manual patrolling, the other user's manual patrolling is not resumed.
If you do not stop your manual patrolling yourself, it will continue until a rule-based patrolling or a user with a higher priority takes over. When the rule-based system patrolling stops, the system resumes your manual patrolling. If another user starts a manual patrolling, your manual patrolling stops, and will not be resumed.
When you stop your manual patrolling and you have defined an end position for your patrolling profile, the camera returns to this position.
