Configure access requests
You can use several types of access control events, such as Access denied and Access granted. To enable access request notifications, you must associate the type of event with the event category Access request. By default, the type of event Access denied is associated with event category Access request. Until you change it, access request notifications are sent only when someone is denied access. To change this setting, follow the steps listed below.
Requirements
You must enable notifications for the role(s) that operators belong to. On the role, click the Access Control tab, select Access Control, and then select the Receive notifications check box.
Configuration
  1. In the Site Navigation pane, select Access Control.
  2. On the Access Control Events tab, in the Access Control Event column, locate the event type that you want to edit.
  3. To disable access requests for an event type, in the Event Category column, click , then clear the Access request check box.
  4. To enable access requests for an additional event type, in the Event Category column, click and select the Access request check box.
  5. Save the changes.
