Connectors (explained)
A connector facilitates import of raw transaction data from the transaction source, for example the ATM, into the event server associated with the VMS.
The built-in connectors available are described in the table:
Name |
Description |
TCP client connector |
Use when the transaction source delivers the transaction data through a TCP server interface. This connector has two settings that you can specify: host name and port number. |
Serial port connector |
Use when receiving transaction data as input on a serial port on the event server. |
Connectors developed through the MIP SDK may also be available.
