Create a view
To create new views with different layouts and content combinations:
在工作空間工具列中,選取設定。
On the Views pane, select the view group to add the view to.
At the bottom of the Views pane, select Create new view
Choose a layout and number of view items.
Name the view.
再次選擇設定以結束設定模式並儲存變更。
If your system administrator changes camera properties and user permissions in the XProtect VMS system, it may require you to re-create one or more views.
