Create a view group
You can make it easier to find and manage your views by organizing them into groups. Your system administrator may already have set up some groups, but you can usually create your own within existing view groups.
在工作空間工具列中,選取設定。
On the Views pane, select the Private or shared view group that you want to add a group to.
At the bottom of the Views pane, select Create new group
Name the group.
再次選擇設定以結束設定模式並儲存變更。
You can now create views within your new group.
