Copy a view or view group
You can copy a view or a group with all its views and paste them to another place on the Views pane.
If you have permissions, you can also copy a private view to a shared view group, making it available to more users.
在工作空間工具列中,選取設定。
Select the view or group you want to copy.
At the bottom of the Views pane, select Copy
, or press CTRL+C. -
Browse to where you want to paste the view, select Paste
, or press CTRL+V. -
To rename the copied view or group, right-click it and select Rename
