Assign a shortcut number to a view
Assign shortcut numbers to views so you can quickly switch between views. See Default keyboard shortcuts.
Select the view you want to assign a shortcut number to.
在工作空間工具列中,選取設定。
At the bottom of the Views pane, in the Shortcut field, enter a shortcut number, and then press Set.
The shortcut number appears in parentheses before the view name.
再次選擇設定以結束設定模式並儲存變更。
