Play sound notification on event
You can configure XProtect Smart Client to play sound notifications when specific events related to a camera occur.
Your system administrator must have configured notifications on events on the XProtect VMS system server.
在工作空間工具列中,選取設定。
2. Select the view and the view item you want to enable sound notifications for.
On the Properties pane, in the Sound on motion detection list select:
Always off: Disable sound notifications for events.
Always on: Play a sound notification for each detected event.
To apply the same settings for all camera, hotspot, and carousel view items, define the settings for one view item, then select Apply To All in the Properties pane.
再次選擇設定以結束設定模式並儲存變更。
