Add an overlay button to a camera view item
You can add overlay buttons
當您在即時模式中將滑鼠遊標移動到帶有攝影機的個別檢視項目上時,以圖層方式出現於視訊最上層的按鈕。使用覆蓋按鈕時,可觸發揚聲器、事件、輸出,移動 PTZ 攝影機,開始記錄,清除攝影機的訊號等。 to your camera view items to perform tasks such as activating speakers, triggering events, or moving PTZ cameras directly from your views.
Overlay buttons appear when you move your mouse over individual camera view items in live mode.
You can add as many overlay buttons as you need.
Select the view where you want an overlay button.
在工作空間工具列中,選取設定。
In the Overlay buttons pane, select and drag the command to the camera view item.
Place and resize the overlay button.
To change the text of the overlay button, double-click it, then select the check box
to save your change or
to discard the changes. -
再次選擇設定以結束設定模式並儲存變更。
